i m using mikrotik web proxy with hotspot
why my server process is going to too high
it goes to 50% to 90%
when i off web proxy it goes to 3% to 15%
any solution ???
ram 1 gb
processor 2.8 ghz
any solution ???
ram 1 gb
processor 2.8 ghz
Do you have any problems from CPU load? CPU is working (CPU load is going up), and it is good.
when the process goes up
my internet goes slow down !!!
Are you sure that Internet is not slowed down by other factors?
A processor of 50-90 shouldn’t slow the internet..
Thanx 4 replies
when the process touch to 100% ,then internet goes down !!
why it goes to high ???
Hi all!
I openned this topis once again because web-proxy in MT with RB is useless.
I tested it on RB433AH with 8GB MicroSD and with 1 (i write it: ONE) wireless client and after few pages are oppened, processor goes up to 100% and surfing stops for few seconds. After that I can surf for few pages and all over agian, start-stop-start-stop…
Terrible!!! Are there any plans to rewrite proxy and manage it to work? You can’t say that RB433AH can’t manage one client for wireless and proxy,
Is anyone have some advice? I denyed cookies to being cached but no changes,
maybe cpu process till 100% when proxy building cache,..the solution usual im doing is disable nat redirect to proxy port.
Hi. Thx for answer.
No, I tested it for few days so it isn’t in cache build. So, how do you redirect traffic to proxy? By routing it or…?
say now your cache is 20gb on disk and you want to reboot your router with internal proxy enable, it will take -+ 20 minute to building cache, and then make web proxy running, if the same time router building cache, it will slow down or make internet connection down, because nat redirect.
litle tricky im using is, disable nat redirect with scheduler using start time parameter set to “startup” and type this script on event like this :
/ip firewall nat set [find comment="REDIRECT-PROXY"] disabled=yes
:log info "====== DISABLE NAT-REDIRECT-PROXY ======";
nat redirect. to proxy.
6 ;;; REDIRECT-PROXY
chain=dstnat action=redirect to-ports=3129 protocol=tcp
src-address=!192.168.100.3 dst-address-list=!speedtest
in-interface=eth2-lokal dst-port=80
anytime we rebooting the router, nat redirect will disabled.
hth.
