mikrotik queues not working when load balancer used in front
upload photos
Hi i decided to make a new thread because I have a few relaated to the same one and it`s getting a bit confusing going from one to the other.
Now I have a few problems I will try and explain as much as possible.
My old setup was diagram 1.
4 DSL lines Bridge mode
4 Mikrotiks acting as pppoe
Now on each mikrotik I have many queues, queue trees, simple queues, bandwidth management, all different types of traffic that I maked HTTP,HTTPS,VOIP e.t.c e.t.c. I also control the disconnections and connections of customers on the mikrotik, basically everything is done through the mikrotik many months of hard work.
On Ethernet 1 port of the Mikrotik I had the Lan of the ADSL router connected
From Ethernet 2 I connected a cable to my switch that then connected to my RocketM5`s
Everything was working fine in the Mikrotik.
My new setup.
This is a far as I have got
4 DSL Lines Bridge Mode
Tplink tl-er 5120 load balancer
The load balancer has the 4 DSL lines connected to each wan each WAN has pppoe
On the LAN of the tp-link I have subnet 10.1.1.1 (The same subnet I used on my old setup)
From the lan of the tp-link I connect to Ethernet port 1 on the mikrotik.
From Ethernet port 2 on the Mikrotik I connect to my switch that connects to my rockets.
Problem I am facing.
There is Internet connection but none of my queues or bandwidth management is not working, its also not showing any of my marked traffic so I have no control of anything.
I hope someone has had this problem before Ive been asking questions reading but what every I do I can not get it to work.
Here is a photo so you can see the problem.
upload foto
upload
Hope some one can help
you have to select the parent in the first EXE-UPLOAD queue
Hi thats not really the problem. Sorry I tried to explain as best as possible all my marked traffic is not working any more with the new set up. as you can see in fire wall - connections. before it would show all the marked traffic i had http,https,ntp,voip,other e.t.c.
must be because i had pppoe set up before but now i have the load balancer befor the mikrotik and pppoe and nat removed on the mikrotik.
I expected just to plug the load balancer into the same port on the mikrotik without the pppoe and the mikrotik would be doing the same as before. Its on the same subnet as before. As I said on the old setup everything was perfect all working as it should it was working for a year no problems the only thing i changed now was the load balancer before it.
Hope this has explained a little better ps in fire walls connection it just shows (other not my maked traffic any more)
so everything is useless, some thing is wrong and i can not work it out.
Hi I might be getting some were but i dont have enough experiance.
Do i need to enter a dst-nat in the mikrotik ?
