Hi need to get a similar product that R5H, we are using 5-Turbo and the new models of mikrotik card’s don’t support Turbo mode, I tried a few cards but didn’t throughput like mikrotik R5H. Anybody knows a similar card? with similar price?
Thanks for the reply, I tried UBNT XR5 and it work’s great but the price its 90€ and the price for the R5H is 35. I tried also Dbii, F50-PRO but the sensibility its not like R5H. I Will try the others one.
All the Rx for most of the cards now are near -97. Remember the engenius card also has an offset, if you change the power levels outside of default you will be over driving the cards and might damage them. R5H and XR5 show the true powers.
No it’s not normal. Please send me an e-mail to lawrence{at}dbii{dot}com and I can send you replacements.
Certain cases, based on other postings, nstreme turned off might affect it. I would have to know more details about your configuration to better understand what is going on.
Hi hidagar,
We had some issues with our Rx previously, this was part of our recall that we did last year. Although I’m sure there are some that are still out there in the field. Any date code that starts with 09xx for the last 4 digits on the back of the card might experience these throughput and Rx issues. If you’re still interested in a replacement, please let me know.
To us, the R5h is great product if there is no problem with it, but the faulty ratio is too high…
Nowaday, we only use the F50-Pro, this product perform well and so far, we having no issue with it…
