Here is my configuration of “users” file. Could you say which part I should edited?
# Please read the documentation file ../doc/processing_users_file,
# or 'man 5 users' (after installing the server) for more information.
# This file contains authentication security and configuration
# information for each user. Accounting requests are NOT processed
# through this file. Instead, see 'acct_users', in this directory.
# The first field is the user's name and can be up to
# 253 characters in length. This is followed (on the same line) with
# the list of authentication requirements for that user. This can
# include password, comm server name, comm server port number, protocol
# type (perhaps set by the "hints" file), and huntgroup name (set by
# the "huntgroups" file).
# If you are not sure why a particular reply is being sent by the
# server, then run the server in debugging mode (radiusd -X), and
# you will see which entries in this file are matched.
# When an authentication request is received from the comm server,
# these values are tested. Only the first match is used unless the
# "Fall-Through" variable is set to "Yes".
# A special user named "DEFAULT" matches on all usernames.
# You can have several DEFAULT entries. All entries are processed
# in the order they appear in this file. The first entry that
# matches the login-request will stop processing unless you use
# the Fall-Through variable.
# If you use the database support to turn this file into a .db or .dbm
# file, the DEFAULT entries _have_ to be at the end of this file and
# you can't have multiple entries for one username.
# Indented (with the tab character) lines following the first
# line indicate the configuration values to be passed back to
# the comm server to allow the initiation of a user session.
# This can include things like the PPP configuration values
# or the host to log the user onto.
# You can include another `users' file with `$INCLUDE users.other'
# For a list of RADIUS attributes, and links to their definitions,
# see:
# http://www.freeradius.org/rfc/attributes.html
# Deny access for a specific user. Note that this entry MUST
# be before any other 'Auth-Type' attribute which results in the user
# being authenticated.
# Note that there is NO 'Fall-Through' attribute, so the user will not
# be given any additional resources.
#lameuser Auth-Type := Reject
# Reply-Message = "Your account has been disabled."
# Deny access for a group of users.
#DEFAULT Group == "disabled", Auth-Type := Reject
# This is a complete entry for "steve". Note that there is no Fall-Through
# entry so that no DEFAULT entry will be used, and the user will NOT
# get any attributes in addition to the ones listed here.
#steve Cleartext-Password := "testing"
# Service-Type = Framed-User,
# Framed-Protocol = PPP,
# Framed-IP-Address = 172.16.3.33,
# Framed-IP-Netmask = 255.255.255.0,
# Framed-Routing = Broadcast-Listen,
# Framed-Filter-Id = "std.ppp",
# Framed-MTU = 1500,
# Framed-Compression = Van-Jacobsen-TCP-IP
# This is an entry for a user with a space in their name.
# Note the double quotes surrounding the name.
#"John Doe" Cleartext-Password := "hello"
# Reply-Message = "Hello, %{User-Name}"
# Dial user back and telnet to the default host for that port
#Deg Cleartext-Password := "ge55ged"
# Service-Type = Callback-Login-User,
# Login-IP-Host = 0.0.0.0,
# Callback-Number = "9,5551212",
# Login-Service = Telnet,
# Login-TCP-Port = Telnet
# Another complete entry. After the user "dialbk" has logged in, the
# connection will be broken and the user will be dialed back after which
# he will get a connection to the host "timeshare1".
#dialbk Cleartext-Password := "callme"
# Login-IP-Host = timeshare1,
# Login-Service = PortMaster,
# Callback-Number = "9,1-800-555-1212"
# user "swilson" will only get a static IP number if he logs in with
# a framed protocol on a terminal server in Alphen (see the huntgroups file).
# Note that by setting "Fall-Through", other attributes will be added from
# the following DEFAULT entries
#swilson Service-Type == Framed-User, Huntgroup-Name == "alphen"
# Framed-IP-Address = 192.168.1.65,
# Fall-Through = Yes
# If the user logs in as 'username.shell', then authenticate them
# using the default method, give them shell access, and stop processing
# the rest of the file.
#DEFAULT Suffix == ".shell"
# Service-Type = Login-User,
# Login-IP-Host = your.shell.machine
# The rest of this file contains the several DEFAULT entries.
# DEFAULT entries match with all login names.
# Note that DEFAULT entries can also Fall-Through (see first entry).
# A name-value pair from a DEFAULT entry will _NEVER_ override
# an already existing name-value pair.
# Set up different IP address pools for the terminal servers.
# Note that the "+" behind the IP address means that this is the "base"
# IP address. The Port-Id (S0, S1 etc) will be added to it.
#DEFAULT Service-Type == Framed-User, Huntgroup-Name == "alphen"
# Framed-IP-Address = 192.168.1.32+,
#DEFAULT Service-Type == Framed-User, Huntgroup-Name == "delft"
# Framed-IP-Address = 192.168.2.32+,
# Sample defaults for all framed connections.
# Framed-IP-Address = 255.255.255.254,
# Framed-MTU = 576,
# Default for PPP: dynamic IP address, PPP mode, VJ-compression.
# NOTE: we do not use Hint = "PPP", since PPP might also be auto-detected
# by the terminal server in which case there may not be a "P" suffix.
# The terminal server sends "Framed-Protocol = PPP" for auto PPP.
DEFAULT Framed-Protocol == PPP
Framed-Compression = Van-Jacobson-TCP-IP
# Default for CSLIP: dynamic IP address, SLIP mode, VJ-compression.
DEFAULT Hint == "CSLIP"
Framed-Protocol = SLIP,
# Default for SLIP: dynamic IP address, SLIP mode.
DEFAULT Hint == "SLIP"
# Last default: rlogin to our main server.
#DEFAULT
# Login-Service = Rlogin,
# Login-IP-Host = shellbox.ispdomain.com
# # Last default: shell on the local terminal server.
# DEFAULT
# Service-Type = Administrative-User
# On no match, the user is denied access.
hamed User-Password == "letmein"
Group = "full"
