I’m currently using Radiator with a Mikrotik 1100 RouterOS v5.24. I have radius authentication and accounting working and my radius server is passing the Mikrotik-Rate-Limit to the Mikrotik as it should. I can see this from server logs and the Mikrotik log itself as seen below.
However when doing speed tests with this connection, it appears to be wide open as I’m getting the max speed my network permits. Any ideas as to why this isn’t working?
Thanks for the reply and sorry for the slow response. So I tried it the way you suggested and I see in the logs the Mikrotik applying it, but the filter still doesn’t seem to be working.
