I have never used these boards before. I bought 2 of them the other day.
When setting up the first one as a cpe, it took a couple of hours to get it going. It associated with the ap no problem & provided data to the ethernet end. Today I set up the second one the very same way. Wlan1 is dhcp client, ethernet port is dhcp server, but it will not pass traffic. It associates with the access point ok, I can even use the PING utility to ping the access point and it pings ok. The PC is obtaining an IP from the DHCP SERVER ok, but no traffic passes. What should I check for? A setting out of place perhaps?
You would have to provide us with some more information.
Do you do masquerading/NAT in the CPE/client? Perhaps that’s the missing link?
Best regards,
Christian Meis
No I do not have this set up. I just simply set up dhcp client on the wlan interface and dhcp server on the ethernet interface. this worked ok the first time.
Then you’ll have to post some config from your systems - else noone will be able to help you here ![]()
Best regards,
Christian Meis
its ok now I got it going, your speaking of nat and masqurading jogged my memory, I did do this on the first board. Thank you.
Glad to hear that!
Best regards,
Christian Meis
