Mikrotik RB with huwaie router WIFI
We have a strange issue
We using the huwaei b315 LTE eg, 192.168.8.1,
We disable DHCP on huwaie, and only keep the WIFI active
Plug mikrotik into port 1 of huwaie
ether1 : 192.168.8.2
ether1: 192.168.0.1
enable dhcp for 192.168.0.0/24 on ether1 on mikrotik
Clients connect to WIFI on huwaie dont get dhcp IP, however we can set static ip addresses and it works
I assume the hauwie has some sort of firewall switch security, we have tried every possible setting on hueawie.
Is there anyway around this or some advice would be appreciated
S
You need to understand in which interfaces of Huawei router works DHCP server.
