MikroTik RB1000U Power Supply
I believe that the power supply in one of our RB1000U routers is faulty due to random shutdowns of the router which require a power-cycle to get the router back into service.
Which MikroTik distributors are able to supply replacement power supplies (we are based in the UK) ?
Regards,
Terry Froy
Spilsby Internet Solutions
http://www.spilsby.net/
Maybe bad capacitors in rb1000.
http://forum.mikrotik.com/t/bad-capacitors-on-rb1000/62101/1
If capacitor are OK, try to change power supply for another
honzam,
Thanks for your reply.
This makes perfect sense; so now I have to pull this router from co-lo in order to perform surgery to it :frowning:
After fixing countless RB750s, I guess I should have figured that the RB1000s we had would eventually be plagued with the same issue.
Why can’t MikroTik simply ship non-broken capacitors ?
The system works fine when running the memory tester in RouterBOOT and does not fall over; it seems to only be when the router is subject to high traffic loads which implies higher power consumption (CPU, etc).
Regards,
Terry Froy
