Mikrotik RB1100 wisp?
Hello, im new to mikrotik and mikrotik forum. I have question will Mikrotik RB1100 with following specifications
Product specifications
Details
Product code RB1100
CPU nominal frequency 800MHz
Size of RAM 512MB
Architecture PPC
10/100 Ethernet ports 13
10/100/1000 Ethernet ports Yes
Memory card type microSD
Power Jack 12-24VDC
PoE in 12-24VDC
Dimensions 1U case: 45x75x440mm
Tested ambient temperature -20 to +45C
License level Level6
will be able to run wisp network to 300-500 connections at same time. And which is best mikrotik script that i can use for my own WISP, based on vouchers.
Thanks to all!
It is EOL model replaced with 1100AHx2. 1100AHx2 is also quite old and there are newer CCR and CCS devices which you should consider to use.
And Mikrotik RB751U-2HnD can be used for small wisp 300-500connections?
don’t use it,
known hardware bugs,
EOL
use 951 instead
Then which model you suggest me to i use? Or better is to buy server/pc with good performance and install on it RouterOS?
And which script you suggest me to use for ISP? any tutorial?
Also which mikrotik devices you preffer me to use for link p2p distance 50meters optic visible for speed 100/100 and more?
Please suggest me mikrotik devices from this page http://www.all4net.com.mk/index.php?route=product/category&path=60 Thanks a lot !
It was already suggested to use 1100ahx2 or ccr. For such link go for sxtg ac. https://routerboard.com/RBSXTG-5HPacD
If you have a 1100 ah x2 then you can use it. Its old but still preforms very well.
If you are planning to start a small ISP the device to use will be determined by the traffic you are planning to push.
<300Mbps RB2011 or 3011 should do the job just fine.
Above 300Mbps I would reccomend CCR1009.
And when you grow you upgrade to CCR1036 and then 1072.
You cannot expect rb2011 to perform queueing at 300mbits. Count with 100mbits at most.
