Mikrotik RB2011 in "Router" Mode
I am new to Mikrotik, may you help … ?
Current Scenario : LAN > ASUS Router {Tomato Firmware in “Router Mode” NOT “Gateway Mode” > SXT LTE > WAN > ISP
{ASUS provides WIFI & DHCP server & runs Adblock}
All works good.
Question: Is it possible to replace the ASUS with Mikrotik RB2011UiAS-2HnD-IN with same setup, minus the Adblock (which I can do on a Raspberry PI).
Thanks in advance,
I dont see why not.
The only queston I have is why choose any particular model for the router, (what are your requirements))
Great.
Requirements - basic small office / home.
Next question, is their a setup guide for this, or what is the equivalent Mikrotik mode to Router mode only, NOT Gateway mode ?
Mikrotik is not a consumer oriented plugNplay router.
It does come with a default setup that is secure and is up and running right away.
Plug your WAN cable into ether1 and your LAN into 2,3,4,5 etc and you are up and running on 192.168.88.1 network.
That is the quickset format and simply works!
Then you will want to start tweaking the setup and you must tread slowly. One area at a time.
There is a safe mode at the top of winbox that I use. whenever I do something that is illegal (would lock me out and have to reset to defaults and start over) the router simply kicks me out and allows me to log back in as if I were at the point before doing the stupid config change.
Yes, please download and use winbox as your front end tool to configure the router.!!!
As for router… assuming you want it to be a wifi router then the hap ac2 is a decent choice.
If you are a power user the RB4011 is a beast!!
Personally I am not a fan of combining my wifi and router in one because wifi changes more rapidly and I like to put it where it makes most sense for wifi.
For wired home office I would look at the RB450Gx4 router board (plus enclosure and power supply) and again of course the beast RB4011 (non wifi variant).
Depends a lot on expectations and usage…
Thank you for the time you invested in your reply, of which I do not wish to seem disrespectful. Thank you also for the recommendation of “hap ac2”, may I ask if you recommend it over the “rb2011UiAS-2HnD-IN” ? I have a wifi LAN only.
However, as I have stated I have a SXT LTE, implying I have used Winbox for my current setup.
What I need is direction as to what tweak to make first to have the new Mikrotik perform as a “router” only ie no NAT and no firewall or is it as simple as un-ticking these boxes ?
I am not asking for babysitter…
Sorry Gerry, I have no experience with SXT so didnt realize you were conversant so to speak.
I gather you are getting internet then from wifi and your router is an ALL IN ONE unit distributing wired and wifi interent to your home/office.
You probably know more than I, so I am probably of no much further help, other than to say I would never setup my router without a firewall.
It’s a router, it routes by default anything it knows how and where. So if all you need is simple router without NAT and anything, then:
  1. Create bridge for LAN and add all interfaces except the one connected to SXT.
  2. Addresses and routing:
add address=<external address>/<mask> interface=<external interface>
add address=<internal address>/<mask> interface=<internal interface (bridge)>
add dst-address=0.0.0.0/0 gateway=<default gateway>
  1. Use the helpful “DHCP Setup” button in IP->DHCP Server for nice step-by-step config.
  2. Basic wifi AP config is something like:
add authentication-types=wpa2-psk name="My AP" wpa2-pre-shared-key=<wifi password>
/interface wireless
set [ find default-name=wlan1 ] country="<where you live>" frequency-mode=regulatory-domain \
    mode=ap-bridge security-profile="My AP" ssid=<SSID> wireless-protocol=802.11
No Problem & thanks for trying.
For anyone else - I will detail a little more clear.
Current Setup : ISP > SXT LTE (3G internet connection) > Physical ethernet cable to ASUS Router (running Tomato in “Router Mode” NOT “Gateway Mode” > WIFI internet connection.
Firewall IS running on SXT LTE with enabled DHCP server AND NAT. Firewall is disabled on ASUS, but has enabled DHCP server.
It may be useful to post your SXT config then, but only if you are having issues down the line.
Hello (again..) I purchased a hap ac2 (192.168.2.1). To avoid any setup errors - I did a fresh install (routeros-arm-6.44.3) via Netinstall & did not use QuickSet.
I manually set up all as per "RouterOS - RouterOS - MikroTik Documentation" excluding wifi (I will do later).
I "think" I followed the above instruction (thank you).
I can ping SXT (192.168.88.1).
Problem(s): I cannot ping 1.1.1.1 or do I have internet access.
Any direction as how to narrow the problem is much appreciated,
{The SXT setup works perfect with my ASUS router, so I only wish to change the hap ac2 setup}
SXT LTE Config
jun/14/2019 19:40:30 by RouterOS 6.42.1
software id = Z1Q2-GX3Z
model = RBSXTR
serial number = 99850980033F
/interface lte
set [ find ] band=20 mac-address=AC:FF:FF:00:00:00 name=lte1 network-mode=
gsm,3g
add admin-mac=B8:69:F4:01:34:19 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=hs.vodafone.ie
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge lease-time=30m name=
defconf
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=
192.168.88.0
/ip dhcp-server lease
add address=192.168.88.251 client-id=1:a0:8c:fd:fe:bf:3 mac-address=
A0:8C:FD:FE:BF:03 server=defconf
add address=192.168.88.250 client-id=1:60:a4:4c:6c:b:b1 mac-address=
60:A4:4C:6C:0B:B1 server=defconf
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee
d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you
need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=
Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=
"MC, Class D, IANA # Check if you need this subnet before enable it"
list=Bogons
add address=192.168.2.16 comment="tablets list" list=tablets
add address=192.168.2.15 list=tablets
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
inactive time
add action=reject chain=forward comment="tablet restriction morning"
connection-state=established,new fragment=no reject-with=
icmp-host-unreachable src-address-list=tablets time=
10h-13h30m,sun,mon,tue,wed,thu,fri,sat
inactive time
add action=reject chain=forward comment="tablet restriction evening"
connection-state=established,new reject-with=icmp-host-unreachable
src-address-list=tablets time=15h5m-17h,sun,mon,tue,wed,thu,fri,sat
inactive time
"tablet restriction remove for Adelya to call Russia !" connection-state=
established,new reject-with=icmp-host-unreachable src-address-list=
tablets time=17h15m-19h15m,sun,mon,tue,wed,thu,fri,sat
inactive time
add action=reject chain=forward comment="tablet restriction night"
connection-state=established,new dst-address-type="" hotspot=""
reject-with=icmp-host-unreachable src-address-list=tablets time=
20h45m-23h15m,sun,mon,tue,wed,thu,fri,sat
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=
Bogons
add action=drop chain=input in-interface-list=!LAN
add action=masquerade chain=srcnat comment="###NAT for 192.168.2.0/24###"
src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade"
add check-gateway=ping distance=1 dst-address=192.168.2.0/24 gateway=
192.168.88.250
/snmp
set trap-interfaces=all
/system clock
set time-zone-name=Europe/Dublin
/system ntp client
set enabled=yes primary-ntp=89.234.64.77 secondary-ntp=193.1.12.167
/system routerboard settings
set silent-boot=no
/tool graphing interface
add interface=lte1
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set port=lte1 receive-enabled=yeshap ac2 config
RBD52G-5HacD2HnD
serial number = B4A00A0DD983
add name=bridgeall_exceptSXT
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 disabled=no interface=bridgeall_exceptSXT name=
dhcp1
add bridge=bridgeall_exceptSXT interface=ether2
add bridge=bridgeall_exceptSXT interface=ether3
add bridge=bridgeall_exceptSXT interface=ether4
add bridge=bridgeall_exceptSXT interface=ether5
add bridge=bridgeall_exceptSXT interface=wlan1
add bridge=bridgeall_exceptSXT interface=wlan2
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
add address=192.168.2.1/24 interface=bridgeall_exceptSXT network=192.168.2.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.2.0/24 gateway=192.168.2.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
add action=dst-nat chain=dstnat disabled=yes dst-address=192.168.88.1
to-addresses=192.168.2.0/24
add action=src-nat chain=srcnat disabled=yes src-address=192.168.2.0/24
to-addresses=192.168.88.1
add check-gateway=ping distance=1 gateway=192.168.88.249
I am not really sure you are successfully pinging the SXT (192.168.88.1) as both devices have that same IP config on ether1 interfaces, so your config seems totally incorrect .
You already have a “router / firewall / DHCP / etc” in the SXT, why not make the Hap AC2 a “switch+AP” only device?
See topic below, @vecernik87 even provided a cool script to do all the config for you, for this exact model device you have, Hap AC2.
http://forum.mikrotik.com/t/hap-ac-as-switch-ap/130711/1
Thank You for direction. It was incorrect. I did think something was wrong with the ping time, it was also incorrect.
I believe its fixed. Working for one day with no issue...
Thank you for the alternative suggestion, but if I did that I would learn less...
@Sob by using DHCP client "add address=/ interface=<internal interface (bridge)>" was done automatically. Is this correct ?
General question: I have set-up static ip addresses in the DHCP server & they work as expected.
When a device requests a static ip (that it is free) it gets it & works as expected.
However it does not display this static ip in the DHCP server / Leases. Is it possible to display them here (they appear under Torch).
hapac2 -
jun/17/2019 14:23:23 by RouterOS 6.44.3
software id = QHJT-8N12
model = RBD52G-5HacD2HnD
add name=BridgeAllExceptSXTP1
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n country=
ireland disabled=no frequency-mode=regulatory-domain mode=ap-bridge ssid=
MikroTik24
set [ find default-name=wlan2 ] antenna-gain=3 band=5ghz-a/n/ac country=
MikroTik50
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=
dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=Adelya1234
/ip hotspot profile
add name=dhcp ranges=192.168.3.2-192.168.3.100
add address-pool=dhcp disabled=no interface=BridgeAllExceptSXTP1 name=Mydhcp
add bridge=BridgeAllExceptSXTP1 interface=ether2
add bridge=BridgeAllExceptSXTP1 interface=ether3
add bridge=BridgeAllExceptSXTP1 interface=ether4
add bridge=BridgeAllExceptSXTP1 interface=ether5
add bridge=BridgeAllExceptSXTP1 interface=wlan1
add bridge=BridgeAllExceptSXTP1 interface=wlan2
add interface=ether1 list=WAN
add interface=BridgeAllExceptSXTP1 list=LAN
add address=192.168.3.1/24 interface=BridgeAllExceptSXTP1 network=192.168.3.0
/ip dhcp-client
add address=192.168.3.2 client-id=N300A-IP mac-address=7C:2F:80:FC:FE:98
server=Mydhcp
add address=192.168.3.16 client-id=1:38:2d:e8:b7:64:22 comment=Adelyas_Tablet
mac-address=38:2D:E8:B7:64:22 server=Mydhcp
add address=192.168.3.15 client-id=1:48:88:ca:49:6f:4e comment=MJTablet
mac-address=48:88:CA:49:6F:4E server=Mydhcp
add address=192.168.3.17 comment=gerry-Latitude-E5430-non-vPro mac-address=
3C:A9:F4:4C:23:4C server=Mydhcp
add address=192.168.3.18 client-id=1:b8:81:98:ac:bb:c9 comment=
Gerry_Adelya-HP mac-address=B8:81:98:AC:BB:C9 server=Mydhcp
add address=192.168.3.20 client-id=1:54:27:1e:4b:7:a4 comment=htpc
mac-address=54:27:1E:4B:07:A4 server=Mydhcp
add address=192.168.3.0/24 dns-server=192.168.3.19 gateway=192.168.3.1
set allow-remote-requests=yes servers=192.168.3.19
/ip dns static
add address=192.168.3.1 name=router.lan
add action=masquerade chain=srcnat disabled=yes out-interface=ether1
out-interface-list=all
/system clock
/tool mac-server
SXT Lte
jun/17/2019 14:24:43 by RouterOS 6.42.1
model = RBSXTR
/interface lte
/interface lte apn
/ip hotspot profile
defconf
192.168.88.0
add address=192.168.88.100 client-id=1:74:4d:28:41:ca:49 mac-address=
74:4D:28:41:CA:49 server=defconf
/ip dns static
Bogons
list=Bogons
add address=192.168.3.15 list=tablets
add address=192.168.3.16 list=tablets
inactive time
inactive time
inactive time
inactive time
20h5m-23h15m,sun,mon,tue,wed,thu,fri,sat
Bogons
add action=masquerade chain=srcnat comment="### NAT for 192.168.3.0/24 ###"
src-address=192.168.3.0/24
add check-gateway=ping comment=tomato distance=1 dst-address=192.168.2.0/24
gateway=192.168.88.250
add check-gateway=ping comment="hap ac2" distance=1 dst-address=
192.168.3.0/24 gateway=192.168.88.100
/snmp
/system clock
/system ntp client
set silent-boot=no
add interface=lte1
/tool mac-server
/tool sms
Yes, DHCP client does add address.
And I don’t understand the part about static leases. They are in same list as dynamic ones. So if you defined them and they work, they can’t be there more than they already are. There’s probably some misundestanding here.
