Mikrotik rb3011 switch mode - is it possible?
Dear,
Can you please tell me / indicate if possible use the Mikrotik Router rb3011 in switch mode?
(The provider is asking me this for the local network)
I would appreciate any information about it.
Thank you.
Best regards
What do you mean ? Yes it can work as a switch…
Hello Zacharias,
Thank you for your reply.
I want to know how.
It is only necessary to put it in ‘bridge’ mode ?
Depend what you want to reach with! Do you need vlan-s or not!
But in every case sure it can!
Ok. I understend.
Thanks for your reply and help.
If I have any other questions, I will indicate it.
