Hi:
Why do not you update the version on my router? is always 6.42 and informs me of the new version 6.43.7.
I download the version but it does not update, is it normal?
Please try upgrading manually.
here is a link :
I tried this from file list, but the result is the same. And it happens the same in two rb3011
Check the LOG section. What is written after you issue upgrade command and reboot?
Log is empty. Where I see log?, I should actve log in terminal?
Solved!!
I delete files npk in files
