Mikrotik RB4011
Hallo
my name is Marco, I have a Mikrotik RB4011, is the first time that I use this router.
My network configuration is :
WAN1 : router 4G ISP
WAN2 : router 4G ISP
WAN3 : router 4G ISP
LAN
i have implemented PCC Load Balancing for 3 WAN like descripted in Mikrotik manual, but the navigation is very slowly.
I have tried to connect every single router 4G and the navigation its fast, but when I connect all 4G interface in Mikrotik router, the performance of navigation id bad.
This is my Mikrotik confioguration :
jan/02/1970 00:04:20 by RouterOS 6.45.9
software id = 0JYA-D1NT
model = RB4011iGS+
serial number = D4440D9112F5
add admin-mac=08:55:31:05:1C:CE auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=WAN1 interface=WAN1 list=WAN
add comment=WAN2 interface=WAN2 list=WAN
add comment=WAN3 interface=WAN3 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.100.2/24 interface=WAN1 network=192.168.100.0
add address=192.168.120.2/24 interface=WAN2 network=192.168.120.0
add address=192.168.130.2/24 interface=WAN3 network=192.168.130.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=WAN1
set allow-remote-requests=yes cache-size=5000KiB max-udp-packet-size=2048
servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=
WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=
WAN2_conn
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=
WAN3_conn
add action=mark-routing chain=output connection-mark=WAN1_conn
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN3_conn
new-routing-mark=to_WAN3
add chain=prerouting dst-address=192.168.100.0/24 in-interface=bridge
add chain=prerouting dst-address=192.168.120.0/24 in-interface=bridge
add chain=prerouting dst-address=192.168.130.0/24 in-interface=bridge
add action=mark-connection chain=prerouting dst-address-type=!local
in-interface=bridge new-connection-mark=WAN1_conn
per-connection-classifier=both-addresses-and-ports:3/0
in-interface=bridge new-connection-mark=WAN2_conn
per-connection-classifier=both-addresses-and-ports:3/1
in-interface=bridge new-connection-mark=WAN3_conn
per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn
in-interface=bridge new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn
in-interface=bridge new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=WAN3_conn
in-interface=bridge new-routing-mark=to_WAN3
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add check-gateway=ping distance=1 gateway=192.168.100.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.120.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.130.1 routing-mark=to_WAN3
/tool mac-server
/tool mac-server mac-winbox
Can anyone help me?
