I’m using Mikrotik RB433AH.
What is the maximum capacity/throughput of Miktorik’s interface?
I have checked and getting not more 30 Mbps.
I checked by:
- Marking Auto Negotiation and unmarking Auto Negotiation
- Selecting both 100Mbps Full duplex and 1Gbps Full Duplex
I’m using NAT.
InoX
2
you must not use btest from the device, use btest through the device, 2 computers. It can easy do 300mbps in bridge mode.
I found the problem.Mark routing was also enabled besides NAT.Using NAT I get more than 90 Mbps.But using Mark routing I can’t get more than 30Mbps.
