Mikrotik Rb750 + AP Unifi - Hotspot Mikrotik
Hello
I have a Mikrotik rb750 gr3 with two AP Unifi.
It’s all running through the Mikrotik hotspot.
When I enable the hotspot, APs work but I can not remotely access them through the cloud.
If I disable the hotspot of the mikrotik, if I agree.
Any ideas about it ..
Thank you!
https://wiki.mikrotik.com/wiki/Manual:IP/Hotspot#IP_Bindings
Set a binding for each AP with type=bypassed.
Thanks!
Another thing..
Can I change/edit Cloud´s dns? Can I put other dns like dyndns… ¿?
The cloud ddns service sends encrypted info directly to mikrotik servers so it looks like there is no way to use the functionality with 3rd party services. However, there are scripts you can use that update it:
For dyn:
https://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_dynDNS_behind_NAT
I personally use dynu so I use this script from their site:
https://www.dynu.com/DynamicDNS/IPUpdateClient/Mikrotik-Dynamic-DNS
Thanks.
Ok, I put the scrip it`s working but I can´t reach throug winbox. From other IP Public I ping to the dyndns and respond. Also open Port 8291 (/ip firewall filter add action=accept chain=input disabled=no dst-port=8291 protocol=tcp)
