Mikrotik RB750 configuration help
I want to achieve the following with this unit, I want to connect a centos machine on wan interface with static ips between the machine and the wan interface. Also one lan port will be connected to my local lan with a different ip. In that lan I have a specific centos machine that I will configure the routing table to send all data that is for the wan network through the lan interface of the RB750.
Until now I have set an static ip on the wan interface, I have also set a static ip on the second lan port to my lan. Now I try to ping the lan port I get a response. I try to ping the ip of the wan port of the RB750 I dont get anything. Only these two settings I have changed nothing else. Any help would be nice.
If you can post your ip config here we can take a look and help where needed
If I understand you:
WAN ----- PC-1----------(Interface1)RB750(Interface2)-----------PC-2
