Mikrotik RB750Gr3 & CaptionCall Telephone
I’m not sure where to post this thread… I searched for any posts containing "captioncall’ with 0 results; thus, I would like to post this information for anyone else who may need such information.
I am about to work on the network functionality for a CaptionCall telephone using a hEX router. Since installing the hEX, our CaptionCall phone has been dropping it’s network connection like the plague infected it… :open_mouth:
Network Requirements
Caption Ports:
• Port 80 (TCP) Initiates downloads
• Port 443 (TCP) Initiates captioning
• Port 5026-5035 (TCP & UDP) transmit audio
• Port 5061 (SIPS) Secure SIP with TLSV1
• Port 15000-16999 (UDP) transmit caption
VoIP Ports:
RTP Real Time Transport Codec 711
• Port (UDP) 2000-2200
• SIP (UDP → TCP) 5065
Their network engineers believe the device is secure enough to open up to the Internet… So I will ask the following:
Instead of making individual rules for all of the above, would it not be easier to simply add a Hairpin NAT for the device?
Any advise or suggestions are greatly appreciated!
I am not familiar with that particular service however it could be that the SIP helper is messing things up.
Have you tried:
Modifying SIP Helper
Add the ports they use for SIP signalling to the service ports so that the router is aware of them.
/ip firewall service-port set sip ports=5060,5061,5065
Disabling SIP Helper
Disable sip helper and test.
/ip firewall service-port disable sip
I would try the above first to see if you can get it to work prior to DMZ.
Connected via bridged Loco M2. As per CaptionCall support I even reset the device to factory defaults. I also assigned a static IP for the device. What is not posted are the defconf WAN & LAN masquerade rules.
Service Ports
NAT Rules
The blackened area is my public IP address.
Results
The captioning service does function but as you can see…
Have you tried disabling the service ports and then trying the NAT?
Have you tried disabling the drop invalid forward in firewall filter?
Also clear connections in ip firewall connections after making changes.
I disabled all the drop rules and then enabled them one at a time individually to find the offending rule. Originally I had set the defconf: accept ICMP rule to Drop. This rule change was the cause of the problem.
I thank you kindly for your assistance!
Glad to help! Its kind of stupid that they depend on ICMP for their stuff to work properly.
