Mikrotik RB750GR3 - SaferVpn problems
I use 6.45.7 (Stable).
I have a lot of problem for connect my router to this vpn provider.
When I try to use L2TP/IPSEC, it work with l2tp whitout ipsec. But when I put the IPsec preshared key, it hang on connect. I see in top of screen “connecting…”, but it can to connect to the server.
Anybody can send me the correct configurazione ?
using openvpn, it disconnects from the server every 2 minutes, it does not keep the connection.
If you have a configuration for openvpn, please send it to gianmm@libero.it
THX
