Equipment:
Router: MikroTik RB750Gr3 (hEX) running RouterOS 6.48.6
APs: 5x UniFi (AC and U6 models)
Uplink: Symmetric dedicated connection
Topology: Standard setup: Internet → MikroTik → Switches → UniFi APs
Symptoms:
Uneven bandwidth distribution among users
Speed fluctuates drastically (1 Mbps to 300 Mbps)
Intermittent connection drops
MikroTik ports show “RS” (Router/Slave) status
Question:
What is the correct procedure to enable hardware offloading on the RB750Gr3 in this topology?
Is there a specific configuration required for integration with UniFi APs?
Could this issue be related to UniFi configuration rather than MikroTik?
