Mikrotik RB750gr3 wireguard issue
I am using mullvad vpn wireguard in mikrotik rb750gr3 and using Whatsapp imo call in UAE I also want open specific web site that is blocked her what is the configuration.
RouterOS 7.12.1
# software id =
# model = RB750Gr3
# serial number =
add name=bridge1
set [ find default-name=ether1 ] comment=Main-WAN
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=Main-WAN user=\
    zakairkhan
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.100.2-192.168.100.254
add address-pool=dhcp interface=bridge1 lease-time=10m name=dhcp1
/port
set 0 name=serial0
/routing table
add disabled=no fib name=WhatsApp+imo
/interface bridge filter
add action=drop chain=input comment=naeem disabled=yes in-bridge=bridge1 \
    src-mac-address=78:98:E8:6E:B7:C4/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment="black diamond" disabled=yes in-bridge=\
    bridge1 src-mac-address=98:DA:C4:8B:A1:10/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment="mota dukan wala" disabled=yes in-bridge=\
    bridge1 src-mac-address=CC:32:E5:C5:C9:DE/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment=misri disabled=yes in-bridge=bridge1 \
    src-mac-address=D8:07:B6:D7:F8:AE/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment=room2 disabled=yes in-bridge=bridge1 \
    src-mac-address=C0:06:C3:7F:FE:FA/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment=room10 disabled=yes in-bridge=bridge1 \
    src-mac-address=F4:F2:6D:59:E5:FC/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment="afzal end wala" disabled=yes in-bridge=\
    bridge1 src-mac-address=9C:53:22:04:49:2A/FF:FF:FF:FF:FF:FF
add action=drop chain=input comment=mohsinbro disabled=yes in-bridge=bridge1 \
    src-mac-address=40:ED:00:4B:47:35/FF:FF:FF:FF:FF:FF
set discover-interface-list=LAN protocol=cdp
add interface=Main-WAN list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=193.32.249.66 endpoint-port=\
    51820 interface=wireguard1 public-key=\
    "UrQiI9ISdPPzd4ARw1NHOPKKvKvxUhjwRjaI0JpJFgM="
add address=192.168.100.1/24 interface=bridge1 network=192.168.100.0
add address=10.67.166.112 interface=wireguard1 network=10.67.166.112
/ip cloud
set ddns-enabled=yes
/ip dhcp-server lease
add address=192.168.100.249 client-id=1:d8:7:b6:d7:f8:ae comment=misri \
    mac-address=D8:07:B6:D7:F8:AE server=dhcp1
add address=192.168.100.88 client-id=1:78:98:e8:6e:b7:c4 comment="naeem nai" \
    mac-address=78:98:E8:6E:B7:C4 server=dhcp1
add address=192.168.100.244 client-id=1:9c:53:22:4:49:2a comment=\
    "afzal end wala" mac-address=9C:53:22:04:49:2A server=dhcp1
add address=192.168.100.57 client-id=1:40:ed:0:4b:47:35 comment=Mohsinbro \
    mac-address=40:ED:00:4B:47:35 server=dhcp1
add address=192.168.100.127 client-id=1:50:c7:bf:c2:a9:a2 mac-address=\
    50:C7:BF:C2:A9:A2 server=dhcp1
add address=192.168.100.4 client-id=1:0:12:17:18:83:d4 mac-address=\
    00:12:17:18:83:D4 server=dhcp1
add address=192.168.100.30 client-id=1:98:da:c4:8b:a1:10 comment=\
    "Black diamond" mac-address=98:DA:C4:8B:A1:10 server=dhcp1
add address=192.168.100.32 client-id=1:1c:3b:f3:c3:a1:dd mac-address=\
    1C:3B:F3:C3:A1:DD server=dhcp1
add address=192.168.100.224 client-id=1:d4:6e:e:76:8f:51 mac-address=\
    D4:6E:0E:76:8F:51 server=dhcp1
add address=192.168.100.137 client-id=1:48:22:54:55:c8:c7 comment=\
    "upper Wala new" mac-address=48:22:54:55:C8:C7 server=dhcp1
add address=192.168.100.140 client-id=1:b0:be:76:7b:97:12 mac-address=\
    B0:BE:76:7B:97:12 server=dhcp1
add address=192.168.100.174 client-id=1:38:6b:1c:3f:e6:e comment="siddik " \
    mac-address=38:6B:1C:3F:E6:0E server=dhcp1
add address=192.168.100.38 client-id=1:f4:f2:6d:59:e5:fc comment=room10 \
    mac-address=F4:F2:6D:59:E5:FC server=dhcp1
add address=192.168.100.0/24 dns-server=8.8.8.8,100.64.0.31 gateway=\
    192.168.100.1
set servers=1.1.1.1,100.64.0.31
/ip firewall address-list
add address=192.168.100.0/24 list=out
add action=fasttrack-connection chain=forward disabled=yes hw-offload=yes \
    protocol=tcp
add action=jump chain=forward disabled=yes jump-target=No-Fasttrack
add action=accept chain=No-Fasttrack disabled=yes dst-port=13231 protocol=udp
add action=accept chain=No-Fasttrack disabled=yes dst-port=\
    5242,5243,3478,34784,45395,50318,59234,5222,4244,5223,5228,443 protocol=\
    udp
    tcp
add action=drop chain=forward comment="black diamond " disabled=yes \
add action=drop chain=forward comment="Afzal end Wala " disabled=yes \
add action=drop chain=forward comment=mohsinnbro disabled=yes \
add action=drop chain=forward comment=naeem disabled=yes src-mac-address=\
    78:98:E8:6E:B7:C4
add action=drop chain=forward comment=room10 disabled=yes src-mac-address=\
    F4:F2:6D:59:E5:FC
add action=drop chain=forward comment="upper Wala new" disabled=yes \
    src-mac-address=48:22:54:55:C8:C7
add action=drop chain=forward comment="pata nahi" disabled=yes \
    src-mac-address=1C:3B:F3:C3:A1:DD
add action=drop chain=forward comment="pata nahi2" disabled=yes \
    src-mac-address=50:C7:BF:C2:A9:A2
add action=drop chain=forward comment="pata nahi3" disabled=yes \
    src-mac-address=D4:6E:0E:76:8F:51
/ip firewall mangle
add action=mark-routing chain=prerouting dst-port=\
    3478,34784,45395,50318,59234,5222,4244,5223,5228 new-routing-mark=\
    WhatsApp+imo passthrough=yes protocol=tcp src-address-list=out
    WhatsApp+imo passthrough=yes protocol=udp src-address-list=out
add action=dst-nat chain=dstnat comment="liteap ac" dst-address=86.97.25.76 \
    dst-port=1987 protocol=tcp to-addresses=192.168.100.246 to-ports=443
add action=dst-nat chain=dstnat comment=\
    "mohsinbro https://94.59.97.164:1981/" dst-address=86.97.25.76 dst-port=\
    1981 protocol=tcp to-addresses=192.168.100.57 to-ports=443
add action=dst-nat chain=dstnat comment="mohsin http://31.215.229.233:1988/" \
    dst-address=217.164.194.166 dst-port=1988 protocol=tcp to-addresses=\
    192.168.100.240 to-ports=8888
add action=dst-nat chain=dstnat comment=naeem disabled=yes dst-address=\
    217.164.195.94 dst-port=1989 protocol=tcp to-addresses=192.168.100.88 \
    to-ports=8081
add action=dst-nat chain=dstnat comment="speedup ping" protocol=icmp \
    to-addresses=192.168.100.1
add action=dst-nat chain=dstnat comment="mikrotik " dst-address=86.97.25.76 \
    dst-port=2222 protocol=tcp to-addresses=192.168.100.1 to-ports=80
add action=dst-nat chain=dstnat comment=siddik dst-address=176.205.92.5 \
    dst-port=5555 protocol=tcp to-addresses=192.168.100.174 to-ports=8888
/ip firewall service-port
set irc disabled=no
set sip disabled=yes
set rtsp disabled=no
/ip ipsec policy
set 0 disabled=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 pref-src=\
    "" routing-table=WhatsApp+imo scope=30 suppress-hw-offload=yes \
    target-scope=10
add check-gateway=ping disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=\
    192.168.222.1 pref-src="" routing-table=WhatsApp+imo scope=30 \
    suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=*A pref-src="" \
    routing-table=WhatsApp+imo scope=30 suppress-hw-offload=yes target-scope=\
    10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Dubai
/system identity
set name=tplink
/system note
set show-at-login=no
/tool graphing
set store-every=hour
/tool sniffer
set streaming-server=0.0.0.0:51820
Wireguard will not help.
I tried unsuccessfully.
Xtls reality works fine .
Help me
Your problem is not wireguard its the rest of the config. Too much noise, for me to look at that might interfere with a standard config.
Why are you using bridge filters.
Why is your config more about blocking vice focussing on only allowing needed traffic?
Your dst nat rules are all wrong… (also speed up ping rule serves no purpose) remove.
Allowed IPs is missing persistent-keep-alive=35s for example!
Add/modify:
add address=192.168.100.0/24 dns-server=100.64.0.31 gateway=
192.168.100.1
set allow-remote-requests=yes servers=1.1.1.1
_/interface list member
add interface=wireguard list=WAN
_
/ip firewall mangle
add action=change-mss chain=forward comment=“Clamp MSS to PMTU for Outgoing packets” new-mss=clamp-to-pmtu
out-interface=wireguard1 passthrough=yes protocol=tcp tcp-flags=syn
I see you have servers on your LAN and thus you have to make sure those servers do not go out wireguard.
To do so, you need to capture that traffic before going out wireguard…
No idea what you are trying to do for whats app?? Its not clear so remove all whats app rules for now, until its clear.
/routing rules
add action=lookup min-prefix=0 routing-table=main comment=“Local Bridge traffic stays on router”
add action=lookup-only-in-table src-address=192.168.100.57 routing-table=main comment=“Server traffic goes back out WAN”
add action=lookup-only-in-table src-address=192.168.100.88 routing-table=main comment=“Server traffic goes back out WAN”
add action=lookup-only-in-table src-address=192.168.100.174 routing-table=main comment=“Server traffic goes back out WAN”
add action=lookup-only-in-table src-address=192.168.100.240 routing-table=main comment=“Server traffic goes back out WAN”
add action=lookup-only-in-table src-address=192.168.100.246 routing-table=main comment=“Server traffic goes back out WAN”
add action=lookup-only-in-table src-address=192.168.100.0/24 routing-table=viaWG
comment=" All other bridge traffic goes to wireguard"
Get rid of routes currently and use
/routing table
add fib name=viaWG
/ip route { assumes you have a default route selected in ppoe client settings }
add dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=viaWG
Dear kindly give your Whatsapp number can u please help me through anydesk
My topic is that how to open specific website through wireguard
I cannot advise on a specific item until the config is fixed, and thus we can coherently address the requirement, in a logical manner.
Thus my recommendation is to address the items noted, get rid of whats app for the moment, simplify all rules ( get rid of bridge filters and make firewal rules default) and then we can progress and add more rules. If not interested, which is fine, your choice of course, then I will move on.
