My friend baught RB751, because he had some problems with original router from ISP (it stopped working once per 2-3days). Now he has another problem - the router stops working 3 times a day. Polsat (the ISP) disconnects the client 3 times a day to calculate used date (I believe). After finishing the session, MT can’t reconnect to the network showing:
→ reseting
→ initializing
→ disconnected.
Only unplugging and replugging to the electricity helps to reconnect.
The other thing is, that when I put the number given by ISP (*99#) it shows “dialing out” and nothing happens.
The LTE Scanner shows only “unknown” interface and there is no way to scan LTE networks.
What shall we do to make it working properly?
