Mikrotik RB951-2n pptp server issue
Goodmorning to all.
I use RB951-2n for home network with pptp server enabled.
Everything is ok i can connect to vpn from internet (have open port 1723 to firewall, internet access is via pppoe over bridge modem, i connect from win xp machine with vpn connection) have set same ip pool to local network so i can ping other machines (proxy arp enabled to bridge interface) so far everything works…
BUT
after some days -or- try to figure out under some circumstances (eg. number of times i connect-disconnect, sometimes client disconnects abnormaly eg. forced shutdown) well something causes router to drop vpn client requests to local network.
VPN connects normally i get ip but not having access to local network for no apparent reason after days of normal operation.
Even winbox cannot connect to router from vpn client.
I have latest routeros 6.12 and the same problem was with previous versions 6.11 and 6.10 as far as i remember.
The only way to bring back functionality (access to local network from remote vpn client) is to reboot router.
Anyone having the same issue?
Can you try this pre-release RC version to see if it helps? http://www.mikrotik.com/download/share/wireless-fp-6latest-mipsbe.npk
I read about capsman. very interesting. like unify system from ubiquity.
if it works as expected i am about to migrate my customers hotspots from ubiquity to mikrotik.
However adding the package to root file list and rebooting router does not install it.
Do i need to upgrade ROS to 6.13 to install the capsman version you suggested me?
Thanks in advance.
