Hello!
I have a MikroTik router RB951 and amateur network. With WinBox, I reinitialized the configuration without checking the default configuration. there I am utterly lost; there is no signal WIFI and even cable, I can not access to http://192.168.88.1/. I am completely lost. Need help
Thanks!
The router only lights up with the adapter plugged in. I pressed the reset button for three seconds but still failed
I’ve a similar problem with a 2011. It’s been great for a few years but after an update I screwed the config. Did a reset as I’ve done before and got the display for default admin password suggesting a clean start.
BUT I can’t access via 192.168.88.1 and no default WiFi service.
Tried reset a number of times and via ‘front panel’ reset configuration but always same result.
Any ideas?
- Connect MikroTik via cable to your computer.
- Run WinBox on your computer.
- Click on “Neighbors” card.
- Click “Refresh”.
- Connect with the desired device by MAC address.
