Hi all,
I was netinstalling the latest version of the software using a script file to change the default configuration on my Routerboard rb951g-2HnD.
While flashing starting from PXE (with reset button) I could read on my laptop LAN CABLE UNPLUGGED, and it stopped updating giving an error with timeout issue.
Now I cannot start it anymore from ethernet, and even if I try to reset it, or start from network, I get the loop of blinking that you can see in this video.
https://www.youtube.com/watch?v=U14_VhM-t1o&feature=em-upload_owner
Can someone support me with my device?
If I could save it, and I would install the npk with updated software using no script, which one would be the configuration applied? I would have the usual 102.168.88.1 address to access from eth2?
Thanks.
