Mikrotik RB951Ui-2HnD PoE not working
Hi guys, I have a problem.
I have the Mikrotik RB951Ui-2HnD but neither the poe in nor out are working, It currently have the version 6.40.3 but when I go the part of system/routerboard/poe settings it shows me that the poe version is 0.0, I dont know if it has something to do with the problem but maybe.
Any ideas on how to solve it?
What device are you trying to power? Remember that model can only output what it gets into it. The standard PSU is 24v so it won’t power much other than mirotik AP’s or Ubiquiti kit.
Same goes for the power in, 24v only.
Are you sure port 1 is working? Does the router boot up when you supply poe power to the port or do you need to power the router using the power jack?
Port 5 poe-out settings are in /interfaces. Click on Interfaces and bring up the details for port 5 and click on the POE tab. Settings are “auto on”, “forced on” and “off”. The Port 5 LED will be red when supplying power.
Your /System/routerboard/poe settings are at default. Don’t worry about them.
