Mikrotik RB951Ui-2HnD , wireless users does not capture ip addresses from network 192.168.88.0
Hello Mikrotiks partners . I Was setting up a Mikrotik RB951Ui-2HnD and configure out the wireless interfkace. The problem is that the wireless clients as smartphones
get connected but capturing Ip Address from a unknown network 192.168.1.0. I Upgrade it to the last version buuret don´t works. All the wired PC and laptops captured the right network ..88.0.
Any one has already solved it ? Thanks !
The ROuterBoard was affected by a vulnerability on september 2018 and I upgraded with the patch recommended by mikrotik.
