Hi! My ISP provides a modem Avenor V-ME500 Rev B (http://www.intertelecom.ua/ua/oborudovanue/modems/v-me500) when connected. I tried to connect it to the router RB951Ui-2HnD, but USB-modem port is not in the menu System-Ports. Screenshot attached. Version 6.32.1 firmware on the router. I tried to do reset to the default settings, but nothing helps. Is it possible to connect the modem to the router?
please send supout to support@mikrotik.com we will try to add support for this modem
Hello!
To OlegkaOwl
Is there any changes with your situation? Have you tried 6.34?
To kristaps
Can you please check if Huawei EC 306 (Rev. В) modem supported?
The mikrotik technical support said that the cannot support Avenor V-ME500 because “because we have already 2 modems vendorid=0x05c6 deviceid=0xf000 (// Siptune LM-75, // Micromax MMX 300G). we are very sorry that we could not add support for this modem.” It’s technical support answer.
I use Huawei EC 306-2 (Rev. В) - supported (> 50 device RB951Ui-2HnD).
Thanks a lot for your reply OlegkaOwl !
Have a nice day!
