Your opinions about this model: MikroTik RB951Ui-2Hnd?
Who used? How was it? Advantages and disadvantages? How does this device behaves with usb 3g/4g modems?
- This is one of our older models. We have hAP series now also available, at lower price.
- The modem support is identical for all MikroTik devices that have a USB port.
Is it true, that:
-MikroTik RB951Ui-2Hnd - Made in Latvia?
-MikroTik hAP - Made in China? Do not correctly works with 3g/4g modems?
- not necessarily, different batches can be made in different factories, we have also factory in Lithuania and other places.
- I already told you, there is no difference, ALL devices have identical support for 3G modems. IF you have problems, let us know what problems, or try other modem.
The software on both of them is exactly the same.
For me huwawei’s usb modems works fine on both
Nobody knows anything. There is only managers sitting there?
As though I did not try to justify RB951Ui-2HnD and to find an adavantages, I finds it at another models, hAP AC lite for example:
Look at the pictures. USB modem will works with “hAP AC lite” better than with “RB951Ui-2HnD”
Are you serious? ![]()
This has nothing to do how well your modem will work. Stop this nonsense please. I told you several times, modem support is identical.
If the amperage is not specified, it doesn’t mean there is no power on the USB port. It just means some missing specification data in the PDF!
Also, you are comparing documents from different sources. Distributors often forget to specify information.
I have the RB951Ui-2Hnd. It is working well for me, but now that you posted this I kind of wish I had gotten the hAP ac lite instead. I guess I just didn’t see that model when I was looking. No reason not to go for the dual band capability if it’s available.
