MikroTik RB951Ui2nD hAP ADSL connection
I have MikroTik RB951Ui2nD hAP 2GHz WiFi. I tried to connect it to internet via adsl line that comes to my place and I couldn’t do it. The seller told me that router cannot be connected directly to adsl line, so I need to buy another router.
Is it true? Why are there phone jack port (PoE in). If yes how I connect it to another adsl router? using lan cable?
Regards
As far as I remember non of MT product has ADSL modem build in. So yes you need another device to connect to he phone line.
PoE in is a “Power over Ethernet” port. It means you can power device via Ethernet cable. https://en.wikipedia.org/wiki/Power_over_Ethernet
Best,
There is no DSL modem currently in the MT products so you will need to purchase a modem and then hand off to your MT via ethernet.
