Mikrotik RBFTC11 support dude?
Hello is supported media-converter program dude?
Seen it on a map of monitoring dude?
it is a simple adapter. It does not have an IP address and has no software.
Then what is the difference between them? (RB260GS vs RBFTC11)
RB260GS determined dude?
Which device is more productive?
The RB260GSP is a switch.
The FTC is an adapter with no logic.
What exactly do you want to monitor? It converts your cable, much like a US to EU power plug can’t be “monitored”
When the client is not in the network (the computer is off) is impossible to know the work of the equipment to the customer:
  • optics cable break
  • power outage
  • theft
