Good afternoon! Are you interested in the code to appear support for LTE modems Intel XMM 7560 Cat 16 and Quectel EM12-G Cat 12 for MIKROTIK RBM33G? And will she appear at all? They have an m.2 socket but they can be used in conjunction with a M.2 to mini pcie adapter. It’s just that Cat 6 modems are a bit outdated.
I meant the drivers of these devices in RouterOS. In fact, I found on Wikipedia a list of supported 4G modems, but there was nothing fresh there. These modems stick to the RouterOS ? There is a new list of supported lte modems?
yes, one person use m2<>mPCIe adapter with that module and it works similar to EP06
MikroTik Chateau use that SoC too, EG12 but not in Global version.
Will the Intel XMM 7560 Cat 16 work?
I don’t know bcs this is a not module but SoC who is used in many modules like Fobocom - I personal not like that vendor bcs I not have any answers from their support.
exacly, that PCB have got prepared M.2 socket and we can just wait for new era of devices with M.2 & (EG16/18 and/or RG500Q) SoC modules. We must wait.
We not run the fibicom without a AT Command book, the seller not prodive it, the Fibicom support not answer to us and we stop at 1 unit of this device.
If you want use it then proper docementation and support is a first step..
I write in general… I have this and few others documentation but what we need is to know how to
*) change a mode between ECP/MBIM/ADB on module
*) Disable USB3.0 bus, for use USB 2.0
*) do a Cell Lock if it’s supported
*) get all signals data if RouuterOS not show them
*) setup manualy APN if RouterOS cannot do that properly
*) set a own IMEI on module if possible
Those are topic’s who must be answered in our projects and official support, distributor not prodive answers and we migrate to Quectel modules.
is accessible in USB-mode in v6.49.x ( used 6.49.15 ) … but not in v7.x.x ( seems ACM usb-serial-support is removed in v7 [?] )
modem show’s no signs of life as a PCIE-device in router-os … there are lots of undocumented AT-commands avail. ( to force pcie-mode [?] ) … but … no coop from fibocom … so far ¯_(ツ)_/¯
ppp-interface is not working because of a PIN-problem … surmise: un-matching mini-pcie–m.2–adapter in use
