MIKROTIK RBSXTKIT
Can I use MIKROTIK RBSXTKIT to take the Internet from the near tower 4g from me and then transfer it to distances of approximately 1 km with high speed.
is that possible ?
thank you .
Let me see if I get it.
You will get internet in a tower, but would it be by cable? In other words, it would have a 4g modem.
SXT does point to point and speed you can look in the equipment documentation; remember not to have obstructions to obtain speed and stability.
https://mikrotik.com/product/RBSXTG-5HPacD-SAr2
If you want to use a 4g modem you have a video where I will show you how to configure it. https://www.youtube.com/watch?v=ILLz4Nm1wRM
(audio in Portuguese but you can see the step by step)
Hi leoservices ,
thank you for help .
i would like ask you another question ,Is it possible to purchase several devices like this and integrate them into one internet connection line to establish a wireless network?
You should be able to, connect them to another RB behind and then use something like ECMP to loadbalance accross them
Please tell me the way.
and how to connect them to another RB? what dose “rb” means?
