I have Mikrotik RB951Ui-2HnD configured as NAT router for my ISP. In order to extend the range of WiFi signal in want to connect another Mikrotik RB951Ui-2HnD via cable with the same SSID and password. can any one help me in setting up my second WiFi router.
Set the wifi the same just with non overlapping frequency and join all interfaces into bridge. Put wire between the devices and it will be working. Put dhcp client on the bridge to get ip.
so in all the Mikrotik routers i have to set the settings as below:
Mode: ap bridge
band: 2GHz-B/G/N
Channel Width: 20/40MHz eC
Frequency: < will change>
SSID: MIKROTIK-ROUTER
Scan List: default
Wireless Protocol: any
Security Profile: default
Bridge Mode: enabled
if I apply the above setting on all the routers will it work…?
It will. Use 802.11 protocol only for common wifi clients. You can also use regulatory domain settings and automatic channel selection. Just experiment a bit…
