Mikrotik restart /shutdown log
Hi, Where are logs/error/warn stored in mikrotik ,if it restarts automatically?
How to debug the reason of restarting ??
The logs are kept after reboot ONLY if they are set to DISK, otherwise they are gone after reboot. You can choose which logs you want to store to disk, and which you want to store to memory. System->logging.
hi
mikrotik log does’t store in mikrotik automatically.
you can use script to export ,system log export to a file,and store in mikrotik file’s.
