Hi guys. I think it is time to move that to public.
We started to worry about future of mikrotik. Look like that they lost their leading developers who understand network technologies.
In October 2023 i reported to mikrotik problem that VPN4 packets from MPLS interface to VRF marked in firewall as packets from unknown interface to unknown interface. I passed endless discussions and after a while it become even worse. In Current ROS 7 beta such packets became not visible for firewall at all. It means that if you have in your CPE router rules :
it will be completely ignored and packets from VPN4 to VRF will completely ignoring forward rules. It should be noted that in ROS 6 firewall working good.
Today morning i got an answer from Mikroitik support that :
I received information from our specialists that MPLS packet which should be routed in vrf is being sent from vrf interface and is seen in output chain (not forward).
If you will set output filter you will see the packets.
It is quite clearly shows that person who answered this question never seen packet flow diagram or not understand how packets flow have to go ( https://help.mikrotik.com/docs/display/ROS/Packet+Flow+in+RouterOS ). And we really started to worry about mikrotik future. Do somebody else have same issue ?
Thank you very much for your concerns and bringing it up to the attention.
v7 is now using new linux kernel with proper VRF implementation, which of course will lead to completely different operation principles. VRF has its own vrfinterface which is used as a loopback for all the traffic that needs to be forwarded to that vrf. When MPLS packet is send to loopback Linux moves it to LOCAL_OUT with all the consequences.
So you want to say that till 7.13 was old kernetl and on 7.14 beta is a new one ? And because of this need to remove functionality which persist in all another routers vendors ?
