I have RB439 with ROS 3.11. I had created a backup named “MikroTik-11112009-1250.backup”.
Then I get that file through FTP, delete the same file on mikrotik, then upload it via FTP.
What happened when I doubled click that file, chose restore, the winbox said
"Do you want to restore configuration and reboot? "
I clicked on “Yes”
The winbox said error “Couldn’t restore configuration - no file name (5)”
What should I do ?
I want to upgrade the ROS to v3.22 or v3.30, I do not want v4.x because I think my scripts on v3.11
couldn’t work on v4.x. But it seems that the file I am looking for only for v4.x. Do you guys have any file
v3.22 higher for mipsbe ?
Thank in advance.
