It has under IP|Firewall a CONNECTIONS list, showing source destination and ports. Sometimes my SIP/IAX device’s don’t register untill I delete the connection. The connection to delete is TCP 5060 or IAX UDP 4569 . I’m using ADSL with pppoe dial out through the ADSL modem.
Is there are any timer I can change to prevent this happening or other way? Is there a script I can run? How?
I have changed the following: Firewall|Connections|Tracking:TCP Established Timeout:1d 00:00:00 to 06:00:00 . Will this solve the problem?
You don’t state what version of ROS you are using.
I have this same problem with my SIP connections when one of my gateways fails and I need to move the connected SIP connections over to the other interface.
we have exactly the same problem on several ROS boxes (2.9.51 and 3.14/3.16) … i temporarly solved it with setting “UDP Timeout” to 3 seconds so it does delete it really fast.
But i would see that only as a dirty workaround and Mikrotik has to fix this issue.
yeah something is wrong with enumerating connections, probably because they are moving so fast.
/ip firewall connection> print count-only
2049
whereas winbox will show you about 5x as many. It’s also interesting that on 4 different routers the answer is 2049.
:put [:len [/ip firewall conn find ] ]
This gives a ranging value around the above number, but still totally inaccurate. This is my guess as to why you can’t remove connections reliably because they are moving targets.
