MikroTik Router cannot ping to host
Hello from _Newbi_e,
I do have a MikroTik Router & Switch with vlans. There are client computer using WLAN from MikroTik Router & from switch. Host from MikroTik WLAN can ping each other & to the router too. And host from Switch Vlan can ping each other. But the problem is MikroTik from its terminal & vlan client cannot ping to the MikroTik WLan computer.
Waiting !!! Thanks in advance !!! :exclamation:
Have you set up intervlan routing as per manual. Tagging vlan to CPU port? I assume you got CRS? More info would be helpful.
I’m new @ this. How & what kind of info should I paste ?
