MikroTik router can't ping connected switches
Hello everyone,
I have a MikroTik Cloud Router and two switches. The issue I'm facing is that, despite connecting the router directly to the switches, they are unable to ping each other. I have already added the SFP ports to the bridge and assigned IP addresses to the devices, but the problem persists.
Any insights or suggestions would be greatly appreciated!
Router config:
feb/10/2025 10:02:04 by RouterOS 6.49.10
model = CCR1036-8G-2S+
serial number =
add name=SFP-Bridge
set [ find default-name=ether1 ] name=ISP-LINK
set [ find default-name=ether7 ] auto-negotiation=no loop-protect=off
set [ find default-name=sfp-sfpplus1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full
add name=WAN
add name=LAN
add name=dhcp ranges=
add bridge=SFP-Bridge interface=sfp-sfpplus1
add interface=ISP-LINK list=WAN
/ip dhcp-client
set allow-remote-requests=yes servers=8.8.8.8,4.2.2.2
add action=accept chain=forward protocol=icmp
/ip service
set www-ssl disabled=no
/lcd
set time-interval=hour
/snmp
set enabled=yes
/system clock
set time-zone-autodetect=no
/system identity
set name=2
Switch config:
2025-02-10 09:06:09 by RouterOS 7.11.3
software id
model = CRS354-48G-4S+2Q+
serial number
add name=SFP-Bridge
add name=bridge1
set [ find default-name=ether49 ] auto-negotiation=no mac-address=\
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no loop-protect=off
speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] disabled=yes loop-protect=off
set [ find default-name=sfp-sfpplus3 ] disabled=yes
add name=WAN
add name=LAN
/ip hotspot profile
add name=vpn ranges=
/port
set 0 name=serial0
/ppp profile
set *FFFFFFFE local-address= remote-address=vpn
add bridge=bridge1 interface=sfp-sfpplus1 priority=0x20 trusted=yes
add bridge=bridge1 interface=ether49
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
add bridge=bridge1 interface=ether25
add bridge=bridge1 interface=ether26
add bridge=bridge1 interface=ether27
add bridge=bridge1 interface=ether28
add bridge=bridge1 interface=ether29
add bridge=bridge1 interface=ether30
add bridge=bridge1 interface=ether31
add bridge=bridge1 interface=ether32
add bridge=bridge1 interface=ether33
add bridge=bridge1 interface=ether34
add bridge=bridge1 interface=ether35
add bridge=bridge1 interface=ether36
add bridge=bridge1 interface=ether37
add bridge=bridge1 interface=ether38
add bridge=bridge1 interface=ether39
add bridge=bridge1 interface=ether40
add bridge=bridge1 interface=ether41
add bridge=bridge1 interface=ether42
add bridge=bridge1 interface=ether43
add bridge=bridge1 interface=ether44
add bridge=bridge1 interface=ether45
add bridge=bridge1 interface=ether46
add bridge=bridge1 interface=ether47
add bridge=bridge1 interface=ether48
add bridge=bridge1 interface=qsfpplus1-1
add bridge=bridge1 interface=qsfpplus1-2
add bridge=bridge1 interface=qsfpplus1-3
add bridge=bridge1 interface=qsfpplus1-4
add bridge=bridge1 interface=qsfpplus2-1
add bridge=bridge1 interface=qsfpplus2-2
add bridge=bridge1 interface=qsfpplus2-3
add bridge=bridge1 interface=qsfpplus2-4
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus4
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=ether49 list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=ether24 list=LAN
add interface=ether25 list=LAN
add interface=ether26 list=LAN
add interface=ether27 list=LAN
add interface=ether28 list=LAN
add interface=ether29 list=LAN
add interface=ether30 list=LAN
add interface=ether31 list=LAN
add interface=ether32 list=LAN
add interface=ether33 list=LAN
add interface=ether34 list=LAN
add interface=ether35 list=LAN
add interface=ether36 list=LAN
add interface=ether37 list=LAN
add interface=ether38 list=LAN
add interface=ether39 list=LAN
add interface=ether40 list=LAN
add interface=ether41 list=LAN
add interface=ether42 list=LAN
add interface=ether43 list=LAN
add interface=ether44 list=LAN
add interface=ether45 list=LAN
add interface=ether46 list=LAN
add interface=ether47 list=LAN
add interface=ether48 list=LAN
add interface=qsfpplus1-1 list=LAN
add interface=qsfpplus1-2 list=LAN
add interface=qsfpplus1-3 list=LAN
add interface=qsfpplus1-4 list=LAN
add interface=qsfpplus2-1 list=LAN
add interface=qsfpplus2-2 list=LAN
add interface=qsfpplus2-3 list=LAN
add interface=qsfpplus2-4 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add address= interface=ether1 network=
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=yes interface=bridge1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway*****pref-src=
"" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
/ip ssh
set forwarding-enabled=remote
/ppp secret
add name=vpn
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os enter-setup-on=delete-key
IP address is set to ether01, the DHCP client is disabled. The switch is doing NAT.
Can you explain how you would like things to work?
Yes, absolutely.
The MikroTik Cloud Router should function as the gateway for the switch. I believe the switch should be configured as a bridge to the Cloud Router, correct?
Reset the switch, no default config
Add brdige
Add all ports to that bridge
Add DHCP client (to the bridge)
That’s about it.
Alright, I’ve done that.
Now, for the Cloud Router, should I set up the DHCP server on SFP1 (the port connected to the switch)?
Normally you would “attach” the DHCP server to the bridge. As well as the IP address.
