mikrotik router configuration GL 750
good morning
Please help would need the following configuration:
  1. I need to create a static ip rules in GL 750 mikrotik as my internal network is 192.168.1.0/24 and ask me to be 10.68.1.0/24
    To address 192.168.1.10 , you would create the static rule 10.68.1.10
    To address 192.168.1.11 - 10.68.1.11 …
  2. I also need to create a port redirections .
  3. Lastly I have to create a VPN with the following parameters
Gateway ip-address 85.158.120.199 217.18.230.244 (my external ip)
Host IP Address
192.168.141.0/24
192.168.141.100 or 237 PROD
192.168.141.228 TEST
192.168.141.40 STREAMSERVE
192.168.141.42 STREAMSERVE (PRINTER)
192.168.1.0 /24 (my external ip)
Service Port
515-517,9100 (from GENERIX)
80,23,445,449,8470-8479
(from CUSTOMER to GENERIX)
Firewall/Gateway IPSEC Compliant
Diffie Hellman group 5 (Phase 1)
Use Perfect Forward Secrecy No (Phase2)
IKE Encryption scheme AES256
Key negotiation method IKE
IKE SA Renegotiation timer 1800 seconds
Hash method SHA1
IPSEC encryption AES256-SHA1
IPSEC Lifetime 3600 seconds
Key exchange Pre-shared Secret
Pre-shared Secret “field empty”
Aggressive mode No
Subnet key negotiation Not supported
thank you very much
