Mikrotik Router only for VPN + multiple remote location
I want to make a centralized VPN multiple network in my company. But I cant change the master firewall/gateway in the HQ to mikrotik, would be dificult. I want to connect the mikrotik in the HQ-s local network (192.168.0.0/24).
The mikrotik routers IP is 192.168.0.3. I forwarded the pptp connections to the mikrotik.
I used this tutorial for the basic config: http://wiki.mikrotik.com/wiki/PPTP_VPN_-_multiple_ADSL_remote_locations_to_Cental_Office
It works fine. Every subdomain see the other subdomains (I have 12 subdomains/remote locations with mikrotik routers). Every subdomain can see outside the mikrotik, to 192.168.0.0/24, but from the 192.168.0.0/24 cant see behind the mikrotik.
I used this tutorial for the solution: http://wiki.mikrotik.com/wiki/Manual:Simple_Static_Routing
I added a static route in the master firewall/gateway to the subdomains with gateway 192.168.0.3, but nothing changes.
Thanks for the help!
