If all mikrotik router can be Set up as hotspot or
There is a seperate models mikrotik router can be set up as hotspot?
I have mikrotik hap lite… I want to upgrade my mikrotik to a much more powerful mikrotik router.
Well then if its a wifi router then the RB4011 with wifi would be such a beast.
All MikroTik routers run RouterOS and can be setup as hotspot.
You can use a router without wifi as hotspot and use a Cisco Wifi accesspoint if you like.
