Your requirements are poorly stated.
You want all 2.5 gig ports but remember the 5009 is limited to routing realistically at around 3gigs.
So if you had 8 ports all capable of 2.5 gigs, you wouldnt achieve WAN throughput greater than 3 gigs at any one time.
If that is not a concern to you and simply want devices on the LAN to talk to each other at 2.5gig speeds (same vlan)
then get the 5009 and attach it using the spf+port to the CRS310 with 8 2.5gig ports…
If you actually get 10 gigs from an ethernet provider or more, then you need to look at the CCR2116-12G-4S which should give you16gigs of throughput and attache the CRS310 to that.
