Hello everyone. I am facing a strange problem on my network. I have a
routerbard 433 mikrotik with the installed version 4.10. but this problem has remained
even in earlier versions. currently have two MacBooks and both can not access the Internet Across the mikrotik. the problem is in the dns server. using external dns such as Google internet works normal. on PCs running Windows or iphones that staff has everything works normally. will be some problem on the mikrotik?
do other PCs work in the same location as the Macs? Did you enable “remote requests” in the DNS settings on the router? What does “nslookup google.com” say in the Mac terminal command ?
We have few Macs in the office and at home, they all work perfectly.
What is your configuration of /ip dns?
