Mikrotik RouterBoard mAP RBmAP2nD Ethernet Ports
Can I use one as a local port and one as a WAN port?
Can I configure the local port to do DHCP over the LAN?
Will it do a wireless WAN?
Thanks in advance. I did some searches but couldn’t seem to find any direct answers.
Best
David
In order of asking:
1- yes
2- yes
3- yes depending on the access point you’re going to connect to (e.g. WPA3 is not supported on mAP, you need wifiwave2 package and that will not run on this device)
THANK YOU!
Very much appreciate the direct and timely response.
Best,
David
