Hello, I have mikrotik RB2011 UAS-RM and i want to install it as the switch, but the procedure, can u help me with some support plz?
Thx for your helping
I assume you want ether1 to be your route out …
- From the Bridge menu add a bridge. From the Bridge Settings menu check Use IP Firewall.
- From the Bridge / Ports menu add ether2 and ether6.
- From the Interfaces menu set ether2 and ether6 Master Port to none.
- Also set ether3, ether4, and ether5 Master Port to ether2.
- Also set set ether7, ether8, and ether9, ether10 Master Port to ether6.
- From the IP / Addressing menu set an IP for the bridge interface (optional).
