MIKROTIK ROUTERBOARD WAP 2ND
http://www.cdr.pl/p4675,mikrotik-routerboard-wap-2nd.html
More info in the brochure: http://www.mikrotik.com/download/share/wAP.pdf
I’m assuming more information will be up on routerboard.com soon as well?
Yes, of course, but brochure contains all the essential info, site will contain the same
wAP 2nD on stock, white and black :slight_smile:
We will make detailed photos soon.
Great looking product! Thanks Mikrotik.
The security screw and rear cable entry option are good ideas.
I’m also very happy to see 802.3af/at on the spec sheet :slight_smile:
Why the cable has to be unshielded? Aren’t you able to make active poe with shielded cables?
They did something wrong with the pcb design … i gues there are some filters connected to ground and that 48V is to much for these components …
How groundig with active POE? Normis please more info…
The same problem is in DynaDish5?
Hi guys,
I’ve read that you cannot use shielded cables with these units? Is that correct?
Also do they work with CAT6 cabling? i.e. Does POE & Data sent correctly?
Cheers!
