I’m have a Wireless network composed by 400 ap. In this moment I would like to change backbone’s access points with Mikrotik boards. Both Deliberant and Mikrotik says that is possible with the last firmware.
Has anyone of you done some configuration with mikrotik and deliberant ( via wds - better )??
I have a dhcp server at first with a CISCO 2960 switch that create 2 vlans.
I configure the mikrotik board and I can obtain an IP address correctly from my dhcp service.
The second ap is connect like station bridge on 5ghz signal.
So there is a backbone from Mikrotik and Deliberant.
This is the initial situation.
I cannot obtain an IP from Deliberant even though it is perfectly connected and ping works!!
The conf of 2 devices are:
“x.2 ( interface.vlan-id)”
5ghz:
bridge1 : eth1.2
wlan1.2
wlan2.2
2,4ghz:
bridge2 : wlan2.3
wlan1.3
wlan2
bridge1 IP 10.10.109.5/24.
