estricting SKIN only to connecting to a Wi-Fi network and entering the password
For end users, I need to create a limited view which, after connecting to Wi-Fi (MikroTik mAP), will allow only selecting a Wi-Fi network and entering the password. In RouterOS v6 it was possible to limit QuickSet only to CPE mode, which opened as the start page. Unfortunately, in RouterOS v7 you have to keep the Wireless table enabled, a login (username/password) is required, and you also need to unlock part of QuickSet.
The MikroTiks will be delivered with PLC controllers as an IoT gateway. The end user must have access that allows them to connect the device to their home Wi-Fi network, i.e. they do:
Connect to Wi-Fi → 10.10.10.10 → Select Wi-Fi network + Connect
I’m also looking for paid support.
