Mikrotik RouterOS UPS Support
i have connected a UPS with Serial Cable it called DB9 connector cable with RouterOS but in ups option its not working …
is there any specific models of ups which will run with mikrotik routeros??? or is there any special cable to connect the ups to router os??
Arman
As far as I know only APCs are supported.
thanks for your replay…
right now i have a ups named SALTEC with DB9 connection and it was working with my windows 2008 server and ups uses DB9 straight cable like 1 to 1, 2 to 2, 9 to 9… may be if i use RS323 cable then it will work ?
Arman
Probably not given how I think only APC is a supported vendor.
It’s here:
http://tandem.ck.ua/ups_mt-eng.php
http://tandem.ck.ua/ups_mte-eng.php
http://tandem.ck.ua/ups_mtm-eng.php
